Originalmente inviato da Umberto Ciao Faustino, così non è facile dirti, occorrono maggiori dettagli.
Es.: quale setting hai selezionato per il governor mode? i valori di batterie/motore? RPM? ecc.
Perché non invii gli screenshots? |
questi sono i dati che sono salvati nel talon :
# Castle Link Data File
# Created: Thursday, January 05, 2017
# Do Not Edit This File By Hand
Auto Rotate Enabled: True
Auto-Lipo Volts/Cell: 3.2 Volts/Cell (*)
BEC Voltage: 6.0V (*)
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Brake Strength: 0%, Disabled (*)
Current Cutoff Type: Soft Cutoff (*)
Current Limiting: Insensitive
Cutoff Voltage: Auto Li-Po (*)
Desired Head Speed 1: 2406
Desired Head Speed 2: 2406
Desired Head Speed 3: 2611
Direction: Forward (*)
Governor Gain: Low (15) (*)
Governor Mode Type: Fixed
Head Speed Change Rate: Medium (5) (*)
Hex55: 85
Initial Spool-Up Rate: Medium (5) (*)
Link Live Enable: Disabled (*)
Motor Start Power: Medium (59) (*)
Motor Timing: Normal (5) (*)
Power-On Beep: Enabled (*)
PWM Rate: 8 Khz
Throttle Response: Medium (5) (*)
Throttle Type: Governor Mode
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Battery Voltage: 22.2000
Vehicle Setup - Gear Ratio: 7.857
Vehicle Setup - Motor Kv: 1100
Vehicle Setup - Motor Number of Poles: 10
Vehicle Setup - Number of Cells: 6
Vehicle Type: Helicopter
Voltage Cutoff Type: Soft Cutoff (*)
