Originalmente inviato da Alexander44 Fatto aggiornamento, rifatto binding, fatto l'autoconfigurazione ma il vario continua a non vederlo viene solo fuori RPM, Temperatura, AS3X, Volt Ric. e Flight log
Ho collegato il vario all'uscita sensore ed ho messo un satellite alla Rx.............. |
Non riuscendo a venire a capo del problema ho scritto alla horizonhobby
Spiegandogli il problema :
Oggetto :Telemetry receiver AR636
Da: i1reg@libero.it (i1reg@libero.it)
12 set 2016 - 16:35
A: <productsupport@horizonhobby.com>
Hello
I have a problem with setting your AR636
as it regards the sensors type variometer and GPS
This is the procedure that I follow.
I turn to a new and clean template on my TX Spektrum DX9
I bind with RX 6 channels AR636 radio I
says DSMX 22 ms and telemetry (9 photos)
Then I go on the telemetry menu and I find that I recognized:
RPM
Temperature
AS3X
V Receiver
Flight Log
It did not recognize the various sensor same x GPS ....................
Altitude manually add diverse and recognizes them on the screen
but no data appears.
I tried with the receiver 9 AR 9350 no problem channels all works and does everything by itself.
It's the 6 channels that needs some other procedure or may be defective?
Thanks for your help and best regards.
Elio Roncagliolo
Attached photos TX screen
Questa è stata la Loro risposta :
[#MQY-272-91650]: Telemetry receiver AR636
Da:
Horizon Hobby Product Support (productsupport@horizonhobby.com)
17 set 2016 - 00:11
A:
<i1reg@libero.it> :
Thank you for contacting Horizon Hobby.
Unfortunately, the AR636 receiver is not compatible with telemetry and the system will not function. I apologize for the inconvenience.
Product Support
Horizon Hobby, LLC
Hours (CST):
Monday - Friday: 8:00 AM - 7:00 PM
Saturday: 8:00 AM - 5:00 PM
Sunday: 12:00 PM - 5:00 PM
1-877-504-0233
(217) 352-1913
RC Airplanes, Multirotors, Cars, Trucks and Helicopters | HorizonHobby
If you need immediate assistance, please call us at 1-877-504-0233 and reference ticket number MQY-272-91650
Conclusioni la AR636 non ha telemetria integrata ! ! !
Peccato........
