Originally posted by il_Zott@04 marzo 2005, 21:39 To enter Set Up mode: you need to firstly connect the ESC BEC connector to the throttle channel of the receiver. Please refer to the user manual of your radio system. The second step is to connect the 3 power-out signal pins to the brushless motor. Before your turn on the transmitter, please adjust the throttle stick to the maximum at full throttle position. Then you could connect the batter to the ESC. You will hear confirmation sounds as soon as your enter the Set Up mode. Please refer to the attached flow chart for details.
Throttle stick positions in Set Up mode: There were 3 positions to correspond to each setting. Simply place the throttle stick in the minimum, middle, and maximum for the corresponding setting. Please refer to the tables below:
Table A
Mode \ Throttle Position Low Middle High
Break No Break Soft Break Hard Break
Table B
Electronic Timing Low-timing Mid-timing High-timing
Table C
Battery Protection 70%(Low discharge rate) 65%(Medium discharge rate) 60%(High discharge rate) |
I punti salienti:
Prima di accendere la tx posiziona lo tick del motore sul massimo.
Poi collega il regolatore e lo sentirai suonare. I suoni ti confermeranno che sei entrato nella programmazione. La posizione in cui metti lo stick, cioè bassa, media, alta, corrisponde ai vari settaggi.
Ma qui mi fermo perchè ho l'impressione che quanto ha scritto il Zott non serva a nulla mancando qualche cosa.
Ad es. il freno : stick basso niente freno, stick medio freno leggero, stick alto freno forte.
Come si fanno a riconoscere i settaggi e a fissarli ?
Quanti suoni ?
