BaroneRosso.it - Forum Modellismo - Visualizza messaggio singolo - [Thread Ufficiale] BRAIN, Virtual Flybar System from MSH!!
Vecchio 15 maggio 16, 15:58   #5557 (permalink)  Top
Diego0.
L'avatar di Diego0.
Data registr.: 05-05-2012
Residenza: Mantova
Ormai ci siamo manca poco all'uscita del nuovo brain come annunciato su Helifreak
MSH Brain2 - What defines "Legendary"? - HeliFreak
When we started work on Brain2 almost 1 1/2 years ago, we kept asking ourselves, what makes a system truly great? For something to earn "legendary" status, it of course comes from the guys using it, and truly loving it. So then the goal is to make a system indispensable. Something intangibly great. Something that exceeds the sum of its parts.
The flybarless system is the heart of the helicopter. It connects to every major component. It's our interface and view into how we connect with our machines. So then we set out to focus on the idea of making Brain2 the ultimate toolbox with a single minded goal of getting the most enjoyment possible out of the machine with the least amount of guessing and frustration.
You guys have seen the work we've done with Rescue. An incredibly complex piece of software in order to make the end user experience a trivial and great one. The new rescue works on Brain1 as a free update and of course Brain2 has it.
But Brain2 has much more. Here's a few highlights of what's new. As we get closer to release, more information will be available.
6 new Brain hardware platforms. From small to heavy duty. With some surprising integration
Faster CPU with hardware acceleration features
Full high resolution logging capability using an on board non-volatile memory. Brain2 takes logging to the next level in an incredibly useful and meaningful way
Event logging for high level review of every flight making it easy to diagnose issues
Full vibration logging on 3 discrete axis, and complete playback of vibration levels from flights
Real time vibration and logging support (view events as they happen)
All new rescue feature (also supported on Brain1)
We are still committed to Brain1 development, as can be seen with the free rescue update coming soon. We are also working on things like support for Jeti which will come with firmware updates in the near future. Brain1 also gets real time vibration analysis.
TRADUZIONE
Quando abbiamo iniziato a lavorare su Brain2 quasi 1 1/2 anni fa, abbiamo continuato a chiederci, ciò che rende un sistema di veramente grande?
Per arrivare allo status di "leggendario", e ovviamente viene questo viene dagli utilizzatori che la amano.
Allora l'obiettivo è quello di rendere un sistema indispensabile.
Qualcosa che si supera in tutte le sue parti.
Il sistema flybarless è il cuore dell'elicottero. Si collega a tutti i componenti principali. E 'la nostra interfaccia e vista sul modo in cui ci colleghiamo con le nostre macchine.
Allora abbiamo deciso di mettere a fuoco l'idea di fare Brain2 con un unico obiettivo mentalità di ottenere il massimo godimento possibile dalla macchina con la minor frustrazione.
Voi ragazzi avete visto il lavoro che abbiamo fatto con Rescue. Un pezzo di software incredibilmente complesso al fine di rendere l'esperienza dell'utente finale banale con un grande risultato.
L'aggiornamento sarà gratuito anche per il brain1 e ovviamente su Brain2 che lo ha già.
Ma Brain2 ha molto di più. Ecco alcuni punti salienti di ciò che c'è di nuovo
6 nuove piattaforme hardware Brain. Dal micro all'HD. Con un' integrazione sorprendente
CPU più veloce con funzionalità di accelerazione hardware
funzionalità di registrazione ad alta risoluzione di utilizzare un bordo di memoria non volatile. Brain2 prende la registrazione al livello successivo in un modo incredibilmente utile e significativo
La registrazione degli eventi per la revisione ad alto livello di ogni volo che lo rende facile da diagnosticare problemi
logging di vibrazioni completo su 3 assi separati, e la riproduzione completa dei livelli di vibrazione a voli
in tempo reale le vibrazioni e il supporto di registrazione (visualizzazione eventi di cosa accade)
Nuovo Rescue, funzione di salvataggio (supportato anche su brain1)
Siamo ancora impegnati nello sviluppo brain1, come si può vedere con l'aggiornamento di soccorso gratuito in arrivo.
Stiamo anche lavorando su cose come il supporto per Jeti che verrà con aggiornamenti firmware nel prossimo futuro.
Brain1 ottiene anche l'analisi delle vibrazioni in tempo reale
cosa aggiungere
COMPLIMENTI A TUTTO LO STAFF MSH PER UN PRODOTTO IN COSTANTE SVILUPPO CON AGGIORNAMENTI GRATUITI.
[IMG][/IMG]
Prôtos Max V2 BrainHD2 - Prôtos 380 Evoluzione Mini Brain2- Prôtos 500 Brain - Oxy3 Qube Brain2 -
Oxy2 FE µBrain2
Diego0. non è collegato   Rispondi citando
