motori rctimer HP2212 880kv
Come da titolo vendo 4 motori rctimer HP2212 da 880KV. Utilizzati poche volte per errata spedizione da rctimer.
Caratteristiche del prodotto: RCTimer High Performance(HP) Series brushless motor built from high quality components: 1. The magnet specification is 40 uh.
2. The bearing is NSK(Japan) or NMB(Japan), it can support a long life.
3. 0.20mm laminations, maximum efficiency and minimum Eddy Current losses.
4. Ultra-flexible motor leads with high-temp 220 °silicone rubber.
5. 3.5mm bullet connectors already installed.
6. With rotor dynamic balance process. Lipo Battery: 2S~4S Motor Weight: 59.06g ( 2.1oz ) Motor Mount: 7g
Intero blocco di 4 pezzi compliti come da foto allegate a 35 euro + spedizione a scelta tra poste italiane o corriere. --------------------------- Nome: Marco Cognome: Campaniello Città: Piazzola sul brenta PD |
