Discussione: motore align
Vecchio 04 marzo 05, 22:39   #11 (permalink)  Top
il_Zott
Adv Moderator
L'avatar di il_Zott
Data registr.: 14-10-2002
Originally posted by Danilo@04 marzo 2005, 20:41
come devo fare per settarlo il mio regolatore?
To enter Set Up mode: you need to firstly connect the ESC BEC connector to the throttle channel of the receiver. Please refer to the user manual of your radio system. The second step is to connect the 3 power-out signal pins to the brushless motor. Before your turn on the transmitter, please adjust the throttle stick to the maximum at full throttle position. Then you could connect the batter to the ESC. You will hear confirmation sounds as soon as your enter the Set Up mode. Please refer to the attached flow chart for details.
Throttle stick positions in Set Up mode: There were 3 positions to correspond to each setting. Simply place the throttle stick in the minimum, middle, and maximum for the corresponding setting. Please refer to the tables below:
Table A
Mode \ Throttle Position Low Middle High
Break No Break Soft Break Hard Break
Table B
Electronic Timing Low-timing Mid-timing High-timing
Table C
Battery Protection 70%(Low discharge rate) 65%(Medium discharge rate) 60%(High discharge rate)
il_Zott non รจ collegato   Rispondi citando
