Avid V2 Robitronic auto rc 1/10 touring
Avid V2 Robitronic auto rc classe touring 1/10.
Radiocomando Turnigy Ts4g con gyro.
Praticamente pronto gara, telaio in carbonio, trasmissione 4wd a cinghia con palo rigido anteriore.
Velocissima vero affare appena revisionata.
Richiesta 429 + s.s.
- servo Hitec Hs7965mg
- ESC Spec. HK
Continuous Current: 100A
Burst Current: 540A
Resistance: 0.0004ohm
Battery: 2-3 cells Lipo (5-10 cells NI-xx)
BEC output: 6V/3A switch mode buit-in
Motor type: Sensorless and sensored brushless motors
Dimension: 43 x 39 x 30mm
Weight: 102g
- Motor Spec. HK
Model: 3650
Kv: 5200
Scale: 1:10
Max Current: 41Amp
Turns: 6.5T
Weight: 165g
Diameter: 36mm
Length: 52.5mm
Shaft length: 15mm
Shaft Diameter: 3.17mm --------------------------- Nome: Andrea Cognome: Mainini Città: Biella |
