Vecchio 25 ottobre 15, 09:22   #5381 (permalink)  Top
Diego0.
L'avatar di Diego0.
Data registr.: 05-05-2012
Residenza: Mantova
Nuovo aggiornamento brain
Available new Software/firmware
Release Notes
- 1.0.017 (Firmware 1.3.083)
- Solved governor over speed with some Nitro engine
- Now Swashplate Rotation in Advanced menu works correctly
- In Tail drag if you move the cursor to zero, now swashplate instantly removes the correction
- Reduced the Governor engage level from 62,5% of the target speed to 56% of the target speed.
- Added Chinese Simplified in the Language menu
- Added Chinese Traditional in the Language menu
- If Standard Receiver is selected unusable parameters in Governor setup are greyed out
- For all the units now the Servo setup is in panel 2 of the Wizard
- Tail setup wizard simplified with only one “plus” and only one “minus” button for either endpoint direction.
- Tail Precompensation now correct either for aileron and elevator
- Rotor clockwise and rotor counterclockwise buttons added in Swashplate Selection panel and removed the Precompensations panel from Tail Setup panel.
- Now in Advanced -> Gov & Level, moving the “Aileron Angle for over” cursor, the swashplate move in the same direction.
- Connections schemes are now correct when reload data from a MTR file with a different receiver type.
- Opening a ”.MTR” configuration file already opened in a text editor, the application doesn’t crash anymore
- Added infos of SW, FW, Voltage and SN at the end of the new generated MTR file.
- The “Unit Type” selection (Brain/microBrain) is now readed from the connected unit automatically.
- Selecting “Ok” on the messages that inform to close the program (language change, Spektrum binding), now directly closes the program.
- The check at the left of “Full Screen” is now correct if program was open in Full Screen mode.
- Corrections and fixes to some instructions
- Small bug fixes and optimization of code
Qui il link diretto
New Software 1.0.017 / Firmware 1.3.083 Available - HeliFreak
Prôtos Max V2 BrainHD2 - Prôtos 380 Evoluzione Mini Brain2- Prôtos 500 Brain - Oxy3 Qube Brain2 -
Oxy2 FE µBrain2
Diego0. non è collegato   Rispondi citando
