Discussione: E-Flite Blade NANO CPS
Vecchio 10 ottobre 15, 23:09   #19 (permalink)  Top
edubu
Data registr.: 29-06-2009
Residenza: napoli
A chi può interessare il commento di un primo utente tedesco con il nano cps
My Nano cps arrived today . tx setup was basic , but the binding was a little diffferent . As soon as you go to bind with the heli "Push bind for 2-3 seconds then push rudder right" if you dont do this the heli will not arm.
the manual also wanted to put the dr/expo on sw "F" i left it on my Fmode"B" ..personal choice. idle up0 is safe mode "blue light" , idle up 1-2 is agility/3D mode "Red Light" . For the panic switch it gives you a mix to use .In My safe mode the heli wants to go foward and left . i have to find a way to do a trim flight like on the 230s. In IU 1-2 it flies perfectly ...
Ill post more as i do more test :-)
Si confermano quindi le esperienze che chi ha il 230S ben conosce
edubu non è collegato   Rispondi citando
