Vecchio 05 ottobre 15, 20:10   #10 (permalink)  Top
2M86
L'avatar di 2M86
Data registr.: 26-12-2004
Immagini: 16
There is a very complicated formula for determining the load factor of a propeller, but in it's most simplistic form, for a 2-bladed prop, the load that a prop places on a motor is equal to the diameter cubed times the pitch or D x D x D x P. For a 2 bladed 10x6 prop, the load factor would be 10 x 10 x 10 x 6 or 6,000. For a 12x8 prop it would be 12 x 12 x 12 x 8 or 13,824.
The more complete formula, which takes the number of prop blades into account is D x D x D x P x Square root (N-1), where N = the number of prop blades. For a 2 bladed prop, the square root of (2-1) is the square root of 1 which is 1, so the term just drops out of the equation.
For a 3-bladed prop, the correction factor is the square root of (3-1) or the square root of 2, which is 1.414.
For a 4 bladed prop, the correction factor is the square root of 3, which is equal to 1.732
So if you have a 3-bladed 9x7 prop, then the load factor is 9 x 9 x 9 x 7 x 1.414, which is 7,216, and this would be roughly wquivilent to a 2-bladed 10x7 prop, which has a load factor of 7,000.
If you had a 4-bladed 12x7 prop, then the load factor would be 12 x 12 x 12 x 7 x 1.732 or 20,950 This would be roughly equivelent to a 2-bladed 14x8 prop, which has a load factor of 21,952.
In the end, if the load factor of 2 props is the same, you will get similar RPMs from the two props, and similar performance.
2M86 non รจ collegato   Rispondi citando
