Vecchio 27 agosto 15, 14:21   #7 (permalink)  Top
toninimillenium
L'avatar di toninimillenium
Data registr.: 20-12-2013
Residenza: Salo'
la factory team ha materiali di gran lunga migliori. sul sito da queste specifiche :
Factory Team blue aluminum sliding motor mount
Factory Team 3mm lengthened 7075 hard-anodized chassis
New suspension arms feature centerline shock mounts and optimized anti-roll bar position
Factory Team 16mm Big Bore hard-anodized threaded shocks with 4mm titanium-nitride coated shafts
Factory Team 5mm 7075 aluminum low-center-of-gravity shock towers with optimized geometry
Factory Team 7075 blue aluminum suspension mounts
Factory Team 7075 blue aluminum steering knuckles
Factory Team 7075 aluminum axles and center drives
Factory Team 7075 blue aluminum one-piece top plate
Factory Team lightweight ring gears
Factory Team lightweight diff outdrives
Factory Team aluminum steering posts
CVA boots on center and rear drive joints
New low-center-of-gravity wing mount
JConcepts Punisher Body and Illuzion wing included
Molded composite radio tray
Molded composite front and rear chassis braces
Tough steel-alloy shock standoffs
Factory Team 83mm "big" wheels included
Caster blocks adjust 14, 16, or 18 degrees with molded inserts
3.5mm light CVA drivetrain with full ball bearings
Factory Team shock and differential fluids included
Losi XE Elite + hobbywing xr8 pro + spektrum dx5c
toninimillenium non รจ collegato   Rispondi citando
