25 agosto 15, 17:34
#2 (permalink)
Top |
Moderatore
Data registr.: 20-09-2005 Residenza: ɐuƃoloq
scusa ma la 9xr pro viene venduta esclusivamente priva d modulo!
ma leggere le caratteristiche prima di compare fa tanto male??? Citazione:
9XR Pro Added Features:
ARM version of er9x radio firmware with EESKYPE simulater GUI support
24 channel support
48 free mixes
Expo, Triple rates, Curves settings
Voice alerts
Telemetry display
Atmel SAM3S ARM Cortex M3 , 32 bit Micro-controller , 512K flash , 64Kb of SRAM
4Mb EEprom for 30+ model storage
Micro SD card (Included)
Mini USB port, for access to SD card files and radio programing
1/2 Watt Audio Amplifier with digital control.
RS232 Serial Port for External telemetry connection through Futaba trainer jack. (for DHT ,DXT)
Logic level Serial Port for external Blue Tooth modules (HC-06,RN42)
Dimable LED Back light
Haptic Buzzer (pager vibrator) for trim center alert and alarm notifications
Real "Tact" switches on menu keys, give positive feedback indication
Built in bootloader. (Firmware can be updated in less than 15 seconds!)
Full built-in Telemetry support for the latest RF modules. New DSM modules coming soon.
Speaker and headphone outputs
Ball Bearing gimbals
Digital Trims
Assignable Switches
Freely Assignable Channel Mixes
Graphical Dual Rate, Sub trims, travel adjust and Exponential
Supports Heli/Aero/Glider and custom Model Types
Programming templates based on model type
Supports M1, M2, M3, M4 stick modes
128 x 64 backlit Liquid Crystal Display
Built in JR & Futaba Trainer Ports
JR Form Factor RF Modules (ORX Dsm2, ORX Open LRS 433Mhz etc)
Programmable warnings
1.5Amp, 5V main switching regulator, with wide input voltage (6.5 - 30V) (uses 3S lipo connection same as 9XR)
Rotary encoder with push switch port (rotary encoder not included - user upgrade)
Support for 6-way switch and more 3 way switches. (User upgrade)
And so much more!!
A full set of user manuals and user videos are available to help learn how to use this powerful radio. Online support and user forums available at: Turnigy® 9XR Transmitter
Spec:
Channnel: Up to 24 supported
Display: 128*64LCD (dimmable Backlit)
Support Type: Heli/Acro/Glid/Custom
Model Memory: 30+
Stick modes: 1, 2, 3, 4
Encoder type: ppm/pcm
Module Interface: JR Compatible (See Related Items Below)
Simulator Interface: Yes (JR & Futaba)
Buzzer/Speaker: Yes
Battery Compartment: 112 x 44 x 27mm
Weight (less battery & Rf Module): 723g
Required:
3S Lipo Battery
RF Module
Included:
Turnigy 9XR PRO Transmitter (Mode 2 Throttle on Left Stick)
Quick Start guide *Note: This version is supplied without an RF Module, please order the relevant RF module from the accessories list below.
**Note: To use the telemetry with FrSky modules the optional plug in cable is required.
| comunque va bene qualsiasi modulo compatibile JR
