Originalmente inviato da romoloman Scusa ma dove l'hai letta, in quella recensione, la frase in neretto ?
Semplicemente dice che mentre DSM2 aveva dei seri problemi in ambienti rumorosi e disturbati, DSMX sembra aver superato il problema.
Inoltre l'analisi è resa obsoleta dalla normativa v1.8.1 nuova... |
Ciao romoloman, non scrive esattamente quelle parole, infatti non le ho messe tra virgolette, è una mia interpretazione di questi paragrafi che ricopio dal test del
DSMX
Well I tested the DSMX system under heavy interference at intensities several times greater than those which would knock a DSM2 system out of action -- and it didn't even blink. DSMX is indeed many times more resilient than DSM2.
Is it more resilient than an FHSS system like the Futaba FASST, FrSky ACSST or Hitec AFHSS system?
Well to be honest, it was hard to tell. These systems all have such good interference rejection capabilities that it's virtually impossible to knock them out, even in an artificially contrived test situation. Suffice to say that although DSMX does have a theoretical advantage, they're all pretty damned good.
DSMX is a system that provides the combined strengths of DSMX and FHSS to deliver the most resilient link possible between pilot and plane.
If you're a DSM2 user who flies anything larger than a parkflier and wish to remain brand-loyal, thus retaining compatibility with your existing equipment then I really do suggest that you upgrade to DSMX as soon as you can.
Ho usato forse a sproposito l'aggettivo migliore, ma la prova mi portava a dire quello...anche alla luce di come ha criticato senza peli sulla lingua il DSM2.
