Questo è quello che ho trovato:
__________________________________________
Minimum requirements:
- PC Pentium 4 1200 MHz
- 256 MB RAM
- 1 GB available hard disk
- DirectX 8.1-capable 3D hardware accelerated video card with at least 32 MB video ram - AGP2x or better. Shared RAM and 3D software emulation is not supported.
- CD drive
- USB port
- R/C transmitter with student or DSC socket of at least 4 channels, PPM mode. Most PCM radios can be switched to PPM mode. PCM transmitters without PPM support are not supported.
- Operating system Windows 98/98SE/ME/2000, XP and Vista, Reflex XTR is working on iMax computers running XP in BootCamp. Parrales will not work.
- *The interface was tested with the usual transmitters on the market. Some models may require some extra equiment like a student socket. In case you are not sure please ask out support at support@reflex-sim.de
Sembra che secondo loro debba andare tutto bene. Tu ricordi di aver letto qualcosa di diverso o di più preciso?
o
"The ability to destroy a planet is insignificant next to the power of the Force" (Darth Vader)o
¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,
