Originally posted by Antonio82@24 febbraio 2005, 21:57 The Futaba 6X FM series of radios for Helis (6XHS)
represents a big step up in sport radio technology.
They access functions with microcomputer speed and
precision, are easier to program than many computer
radios, and are priced to be within the reach of any
modeler wanting high-end features without the high cost.
The Radio is feature rich and covers all of the areas a
Heli pilot requires including CCPM.
CCPM Mixing and several swashplate modes
Switchable and Variable Rate channels add versatility
Hovering pitch and throttle
Revolution mixing
Swash plate type selection
Rudder offset
variable rate also offers proportional channel adjusting,
128-segment LCD display provides better resolution
PPM/PCM feature allows modelers to use either FM or PCM Futaba
mixing, dual rates, electronic trims with computer memory
ATV and servo reversing
Comes with four FP-S148 servos
Adjustable stick length and tension
Fail safe on all channels (For PCM only)
Two user-definable mixes
Trim memory
Manual includes clear, step by step programming instructions
Battery Pack for Receiver Include
Battery Charger Include
3 Way Switch Include
Aileron Extension Wire Include
E' in vendita su flying-hobby.com con questa descrizione, qualcuno mi spiega cosa può fare in Italiano? |
C'è un topic che ne parla basta accendere la radio e tenere premuti i due tasti mode mentre si accende la radio ti appare la scritta mode la selezione avviene tramite + o - se ripremi uno solo dei mode cambi il verso di funzionamento del gas. Saluti Francesco
