Discussione: Caricabatterie scorpio
Vecchio 20 aprile 15, 09:29   #14 (permalink)  Top
raynolds2011
L'avatar di raynolds2011
Data registr.: 18-01-2011
Residenza: pisa
Originalmente inviato da Albo95 Visualizza messaggio
Sennò molto economici ho trovato questi...che mi dite?
The HobbyKing B6 Charger is a simple and compact Lipoly balance charger for 1~6S batteries, and 1-15S NiMh batteries. Featuring built in JST-XH balance plug ports and 2 LED's to indicate charge status and type, the HobbyKing B6 makes an ideal pocket sized charger to keep in your field box .
Specs:
DC Input: 11-15v
Cell Count: 1-6S Lipoly/ 1-15S NiMh
Battery type: Lithium Polymer/Nickel Metal Hydride
Charge current: 100ma-5000ma
Charge Powe: 50watt
Cut off: Auto
Dimensions: 119x92x35mm
OPPURE:
Features:
• In-built 100~240V AC to DC power supply
• Microprocessor controlled• Delta-peak sensitivity (NiMH/NiCd)
• Individual cell balancing
• Li-ion, LiPo and LiFe capable
• Ni-Cd and NiMH capable
• Large range of charge currents
• Store function, allows safe storage current
• Time limit function
• Temperature threshold cutoff (with optional temperature sensor - not included)
• Input voltage monitoring. (Protects car batteries at the field)
• Data storage (Store up to 5 packs in memory)
• Battery break in and cycling.
Specs:
Input Voltage: 11~18v (in-built 100~240V AC to DC power supply)
Circuit power: Max Charge: 80W / Max Discharge: 10W
Charge Current Range: 0.1~6.0A
Ni-MH/NiCd cells: 1~15
Li-ion/LiPo/LiFe cells: 1~6
Pb battery voltage: 2~20v
Weight: 490g
Dimensions: 135x61x112mm
diciamo che potrebbe andare bene anche questo ma con quello che ti ha indicato Culatello, visto che carica fino a 10A hai più potenza di carica e soprattutto, se prendi batterie più capienti, i tempi di ricarica sono comunque contenuti!
per circa 10 euro in più ti conviene prendere il Reaktor!
Sworkz S35 4E Kit - Brushless / S35 3E Kit - Brushless / Sworkz S35 2E Kit - Brushless / Sworkz S350 BE1 - Kit Brushless / Sworkz S14-2 - Kit Brushless
raynolds2011 non è collegato   Rispondi citando
