Vecchio 12 marzo 15, 16:36   #4788 (permalink)  Top
rino2
Data registr.: 30-04-2007
Residenza: Trento
on te lo so dire.. non ho provato... ma da quanto ho letto puoi continuare ad usarla con il precedente firmware... NON con il nuovo... provo a fare un copia-incolla
Android Update Released
Hi Guys,
We're happy to announce that the Android app update is now available on Google play!
Now for some bit of bad news. We were forced to drop the old app on the Google Play Store and implement a new one (long story. We won't go into details). Because of the mechanics of how licensing works on the store, you will have to purchase the app again even though you may have previously. We know this really really sucks! So for the next week the app is only $0.99 to all users. And will return to $5 after the first week expires.
New App can be downloaded here: https://play.google.com/store/apps/d...id=com.msheli2
Release Notes Android 1.0.010:
- Added Spektrum Binding in software
- Cyclic Rotational Speeds are now separated for Aileron and Elevator
- Added Tail Drag Precompensation
- Added Cyclic Pitch Pump
- Added swashplate servo number position
- In wizard (panel 7) doubled steps in swashplate setup
- In Model Size Selection (panel 11) Elevator D Gain preset raised
- Governor: Deadzone range raised now at 0-350
- Bailout ramp range raised now at 0-140
- Removed JR trademark from drop down menu and also from swashplate selection
- Added in cyclic setup instruction "10 degree"
- Minimum and Maximum throttle pulse width for the esc, is visible also in the Wizard
- "Motor is Electric" check now is also in the Wizard
- Added the default value at the end of each balloon in advanced mode (where possible)
- Governor P gain in wizard doesn’t work: fixed
- After the selection of Hott & PPM the schematic connections are now correct
- The selectable Swashplates are now four as in Windows application
- Servo voltage in Wizard and Advanced are now visualized correctly
- The Google License Check are now valid for two months from last valid check
- Flight count & Flight time values are now visualized in the correct position
- Revised all the text and instructions
- Added German translation
Setting changes to check or to do from previous version:
- Set the new separated Rotational Speed for aileron / elevator in each bank before flying (advanced)
Thanks again for your patience and support. We are hard at work making even more great free improvements to the MSH Brain Flybarless System firmware.
Ultima modifica di rino2 : 12 marzo 15 alle ore 16:42
rino2 non è collegato   Rispondi citando
