Discussione: Portata Spektrum dx6i
Vecchio 05 marzo 15, 10:58   #29 (permalink)  Top
ddtvela
L'avatar di ddtvela
Data registr.: 21-04-2011
Residenza: roma
Originalmente inviato da maxrex75 Visualizza messaggio
ho guardato nel manuale, ed è riportato il modulation type, ma all'interno dei menù della radio non è presente.
come posso fare o ho comprato un pezzotto?
Intanto dovresti verificare se la tua radio è dsm2 (le più vecchie) o dsmx (c'è scritto davanti). Se è DSM2 dovrebbe essere comaptibile per definizione.
Se invece è DSMX ti dovrebbe apparire il menù d'impostazione.
Poi potresti anche avere questo problema riportato sul sito spektrum:
DSMX transmitters operating in DSM2 mode
The Spektrum Team has been investigating sporadic reports from DSMX transmitter owners using their products in DSM2 mode. We have discovered that in some rare instances, DSMX equipped transmitters with the Product ID (PID) within this bulletin, may have a backwards compatibility issue that could cause a "hold" with the following superseded DSM2 receivers: AR500, AR6100, AR6100E, AR6110, AR6110E, AR6200 and AR6300.
Note: This bulletin does not apply to DSM2 only transmitters.
If you have a DSMX transmitter with one of the following PIDs, please complete the Transmitter Service Request Form to receive a prepaid shipping label to send your transmitter to Horizon Hobby for a free firmware update.
•Click HERE to complete the Transmitter Service Request Form. Only one form is needed per customer (even with multiple transmitters) please check all boxes that apply and make comments in the Notes field).
•Horizon will pay for ground shipping within the United States and Canada.
•If you purchased your product outside the US and Canada, contact your local retailer or distributor. A list of International distributors may be found HERE.
•If you have further questions in the United States, please call Horizon Hobby Product Support at 877-504-0233.
The PID is located in the battery compartment of your transmitter.
che trovi in questo link
DX6i DSMX 6-Channel Transmitter Only Mode 2 (SPMR6610): Spektrum - The Leader in Spread Spectrum Technology
Sul sito spektrum trovi anche il manuale della DX6I vecchio tipo (DSM2).
Ma la prova di allontanarti l'hai fatta?
Ciao Domenico
ddtvela non è collegato   Rispondi citando
