BaroneRosso.it - Forum Modellismo - Visualizza messaggio singolo - Motore e Regolatore CINISINO per Mini Sportster
Vecchio 23 febbraio 07, 14:59   #1 (permalink)  Top
Principiantes LEVEL GOLD
Data registr.: 04-02-2007
Salve ragazzi ho acquistato questo motore con regolatore
e vorrei sapere da voi esperti se va bene per un MINI SPORTSTER
Specifications MOTOR:
-Rpm(Kv): 1050Rpm/V
-Max Currect: 30A
-Max Eff: 98%
-Recommended Rotor Blade: 6 x 4 to 12 x 6
-Weight: 66g
-Total Length: 33.6mm
-Motor Body Diameter: 28.2mm
-Shaft Diameter: 2.97mm
-Shaft Length: 13mm
-Recommended Input Voltage: 6 - 22 Volt
Specifications Speed Controller:-Size: 62mm x 26mm x 8mm
-Weight: 33g each
-Constant Current: 30A
-Max Current: 40A
-Input Volt: 3V - 18V
-Low-Voltage Cutoff: Auto detect and set
Advantage of the RC Smart Speed Controller
-Low resistence
-High rate PWM
-Sixteen cells Max (with BEC disabled)
-User programmable brake
-Low voltage auto setting based on battery
-Throttle range self-adjusting
-Soft start ramp up
-Runs motor in forward or reverse
-Auto motor cutoff with reset
-Safe power arming program ensures motor will not run accidentally after turn on
-Low torque start
-Auto shut down when signal is lost
CHE NE DITE?
lo vorrei alimentare con una Thunder Power Li-Poly 2100 mA 3S1P 11,1V 15C
Principiantes LEVEL GOLD non è collegato   Rispondi citando
