Ragazzi,
ho trovato il manuale del TX 6XH e gli sto dando un'occhiata per cercare di potervi essere utile in qualche modo.
Però devo darvi qualche brutta notizia... Tale TX, contrariamente a quanto indicato sul manuale, non è dotata di D/R (Dual Rate) sul direzionale, non ha gli esponeziali, non supporta il cambio di piatto ciclico e quindi con lei non si potrà montare il piatto CCPM a 120°.
Riporto di seguito quanto indicato sul sito Futaba a proposito delle
6XA/6XH Manual Notes:
The 6XA and 6XH transmitters are identical as far as available programming, number of switches, etc. Both radios have all programming for aircraft and helicopters. The only difference is the lack of a ratchet in the throttle stick (the throttle is still sprung).
Please download and follow the 6XA/H Super manual for use with your older 6X radio system:
6XA/H Super manual (1,175K)
On page 45 of the manual, the page references a P-AT menu for adjusting pitch ATV. This is ONLY available on the NON-SUPER version of the radio. The Super version has the ATV for channel 6 (pitch) on the ATV menu.
Please note that the following features do not apply to your 6X radio:
The 6X does not have the dual rate for rudder. It does however keep the option to combine the aileron and elevator dual rates on a single switch, the aileron switch, so the elevator dual rate switch can be used for mixing. The 6XAS manual does not cover rudder dual rate setup, so the only text which is inaccurate for your 6X is (page 25 printed or page 27 PDF) the image for D/R Sw Mode 2 will look exactly like the image for DR Sw Mode 1.
The 6X does not have exponential settings. Please remove this page from the PDF file. (Page 26 printed, page 28 PDF).
The 6X does not have swashplate types and swashplate AFR. Please remove these pages from the PDF (53 and 54, printed, pages 60/61 PDF).
Otherwise these manuals are identical and the Super manual is fine to use for your 6X.
Particolarmente pesante è l'assenza degli esponenziali, quasi obbligatori per il T-Rex.
Il venditore è stato particolarmente scorretto, probabilmente la Airtronic (Sanwa) indicata nell'offerta invece è dotata di queste utili funzioni.
Saluti
