Vecchio 13 gennaio 15, 06:05   #5587 (permalink)  Top
rosnik
L'avatar di rosnik
Data registr.: 30-04-2012
Residenza: Brescia
Originalmente inviato da akrobaticone Visualizza messaggio
È uscita la 2.0.14
Index of /companion
[Companion]
  • OpenTX Companion and Companion9x can now be installed side by side on Linux
  • Improved TAB order in dialogs
  • Special Function Start Logs renamed to more appropriate SD Logs
  • Improvements for MAC build
  • Fixes to Google Earth logs export
  • Firmware compatibility warning check added when flashing new firmware to radio
  • Fixed issue with Telemetry Type setting on 9XR-PRO
  • Added Telemetry simulator
  • Added Trainer simulator
  • Added Debug Output window
  • Various texts and translations corrections
  • Various small bug-fixes
  • More reliable method of writing EEPROM.BIN and FRIMWARE.BIN to radio
  • Fixed issue with Edge function INSTANT for V1>2s
  • Fixed buffer overflow in Joystick code
[Taranis]
  • Fixed blank LCD screen at very low temperatures
  • Shortened radio reboot time in case of watchdog reset
  • Fixed timer problem in bootloader, which prevented radio from powering off after being connected to USB
  • Fixed issue with heli swash plate mixing when using notrim
  • Various fixes for double-keys
  • Added switch auto detection in Timer source
  • Totally removed splash screen display if duration is set to ---
  • Back-light turned on sooner at startup (Taranis +)
  • Fixed reverse polarity on external CPPM output
  • Suppressed center beep for non-existing pots
  • Fixed THt persistent timer running after model load (with Throttle at -100%)
  • Fixed buffer overflow for automatic flight mode change audio announcements (if very long model and flight mode names were used)
  • Limited stick throws to 100% when using trainer in add mode
  • Fixed Lua lcd.drawLine(), first pixel was not drawn
  • Fixed missing last column for some bitmap sizes
  • Minor display corrections
Buon aggiornamento
Grazie!!!
rosnik non è collegato   Rispondi citando
