12 gennaio 15, 22:27
#5585 (permalink)
Top |
Data registr.: 25-03-2003 Residenza: Varese
È uscita la 2.0.14 Index of /companion
[Companion] - OpenTX Companion and Companion9x can now be installed side by side on Linux
- Improved TAB order in dialogs
- Special Function Start Logs renamed to more appropriate SD Logs
- Improvements for MAC build
- Fixes to Google Earth logs export
- Firmware compatibility warning check added when flashing new firmware to radio
- Fixed issue with Telemetry Type setting on 9XR-PRO
- Added Telemetry simulator
- Added Trainer simulator
- Added Debug Output window
- Various texts and translations corrections
- Various small bug-fixes
- More reliable method of writing EEPROM.BIN and FRIMWARE.BIN to radio
- Fixed issue with Edge function INSTANT for V1>2s
- Fixed buffer overflow in Joystick code
[Taranis] - Fixed blank LCD screen at very low temperatures
- Shortened radio reboot time in case of watchdog reset
- Fixed timer problem in bootloader, which prevented radio from powering off after being connected to USB
- Fixed issue with heli swash plate mixing when using notrim
- Various fixes for double-keys
- Added switch auto detection in Timer source
- Totally removed splash screen display if duration is set to ---
- Back-light turned on sooner at startup (Taranis +)
- Fixed reverse polarity on external CPPM output
- Suppressed center beep for non-existing pots
- Fixed THt persistent timer running after model load (with Throttle at -100%)
- Fixed buffer overflow for automatic flight mode change audio announcements (if very long model and flight mode names were used)
- Limited stick throws to 100% when using trainer in add mode
- Fixed Lua lcd.drawLine(), first pixel was not drawn
- Fixed missing last column for some bitmap sizes
- Minor display corrections
Buon aggiornamento
----------------------------------------------------- "Il buon aeromodellista atterra dove può" M.B. www.gavonline.it |
