Vecchio 13 febbraio 07, 18:43   #61 (permalink)  Top
nigel_uno
L'avatar di nigel_uno
Data registr.: 05-04-2006
Residenza: Roma, Italy
Invia un messaggio via MSN a nigel_uno
Questa è una spiegazione tratta direttamente dalle FAQ di Scott Gray circa l'uso dei 5,2/5,6V
Why is the Reactor NOT adjustable when other regualtors are?
The Reactor was designed to be very user friendly and provide the best balance between increased performance of the servos and electonics while not damaging or overdriving them; decreasing your radio system's lifespan. Steady 5.2V is available to the RX and gyro/tail servo/accessories and a higher 5.6V power bus is preset to get solid performance and more speed from your CCPM or mechanical mix servos. You do not need to calibrate, adjust or worry that the voltage may not be set right. No voltmeters and resistive loads are required to set as with some other systems. Just PLUG-and-FLY!
nigel_uno non è collegato   Rispondi citando
