Originalmente inviato da luca bianchessi no, io lo step down l'ho messo tra rice e gio, perchè si dice che il giro non va bene a 5,8 volt......... |
Direttamente dalle istruzioni del GY 401
GY401 Ratings
(Integrated sensor type AVCS rate gyro)
Control system:
Digital advanced PI (Proportional Integration) control
Gyro sensor:
SMM (Silicon Micro Machine) system vibration gyro
Operating voltage: +4 to +6VDC
Operating temperature range: -10°C to +45°C
Dimensions: 27 x 27 x 20mm
Weight: 27g (including connector)
Functions:
Gyro operation direction switch, DS mode switch, Control delay
trimmer, Limit trimmer, Remote gain control, AVCS/normal mode
switching
