Vecchio 27 novembre 14, 16:52   #20 (permalink)  Top
miticoalex10
Sospeso
Data registr.: 19-11-2014
informazioni utili, grazie a tutti, per il regolatore ho preso questo in italia perche' voglio stare tranquillo ed un mio amico che ha la versione precedente mi ha detto che sono ottimi, con queste caratteristiche, per la ventola soono in trattativa con una vasyfan usata 120
32-bit Microprocessor with up to 80MHz frequency.
4-14S Lipo support
Max continuous current 160A / 200A in full throttle ( KIII 160A HV / KIII 200A HV )
Active FreeWheeling optional
Motor PWM frequency 8-32K Hz
Throttle resolution up to 1uS
Throttle signal refresh rate up to 1K Hz
Integrated RPM sensor to simplize the wiring for extenal Governor
Optimized the Governor Algorithm to ensure the head speed more stable
Fully CNC aluminium housing with built-in high quality bearing cooling fan to efficient the heat dissipation
Built-In data Logger (logging parameters: battery voltage/current/throttle output/temperature/motor RPM)
Reserve the telemetry interface easy to transfer the realtime data to the third part device
Max RPM 240000 with 2 pole motor ( Heli Mode: Max electric RPM 160000 )
Available with 160A and 200A (4-14S lipo)
Size: 108mm x 52mm x 30mm ( 4.25" x 2.04" x 1.18" )
Weight (with cables): 220g (7.76 oz)
miticoalex10 non รจ collegato   Rispondi citando
