20 novembre 14, 13:54
#44 (permalink)
Top |
Data registr.: 16-07-2008 Residenza: Lucca
Originalmente inviato da carletttta A 6v io ti suggerirei i Savox 1256 SA o SC, costano 10 meno, sono tutti in titanio, digitali, 12bit, filetto centrale 3ma, fanno "solo" 20KG invece dei 24 dei 7954;
Cmq se preferisci i 7954....70 x un servo da 29Kg con 1 ingranaggio in plastica...ok....buono shopping;
Product Description
The HS-7954SH could be considered the most economical high voltage, high torque, coreless servo on the market. Based on the ultra popular HS-7955TG, the HS-7954SH has the added benefit of our high voltage coreless motor. With 403 inch ounce of torque at 7.4 volts, the HS-7954SH is fast too with a 0.12 second transit time when operating on a 2 cell LiPo pack. The HS-7954SH harnesses all this power by utilizing a heavy duty case that incorporates an aluminum heat sink, hardened steel gears, and two strong steel gear pins nested in brass axial bushings. Put it all together and you get one tough high voltage servo at a price that can't be beat.
Features
G2 Digital Circuit
HV Coreless Motor
Dual Ball Bearing Supported Output Shaft
Steel Gear Train (MK first gear) | Presupponendo che son scarso con l'inglese non ho capito dove e scritto che c'e l'ingranaggio in plastica |
