Vecchio 09 settembre 14, 21:41   #44 (permalink)  Top
Maxym77
Data registr.: 08-09-2012
Residenza: Anagni
mi ha risposto adam drake ahhahhaha
aiutatemi a capire...
Hello,
Thank you for including the photos. It helps a lot. First make sure the inner front hinge pins aren’t bent and that the shock ends are screwed on all the way. You also need to make sure you don’t run more than 110mm of droop. We did make a running change to LOSA3586 and make the bone slightly longer.
I hope this helps,
Adam
Maxym77 non è collegato   Rispondi citando
