Originalmente inviato da matrixFLYER Devo 7 non è supportata. |
Il messaggio originale di phractured blue (l'autore di deviationx) su Rc è il seguente:
The Devo7 has 2 issues:
1st is the segmented display. It is very limiting. I am notin favor of providing a non-configurable transmitter that needs to hook up to a computer to tweak. You spend a lot of time making a model work properly as it is. It would be even harder if you had to go back to the computer every time you wanted to change anything
2nd is that it has no USB and a less featured CPU. This means we need to be much more careful with RAM and ROM, and upgrading would be more complicated.
It is just too much work to justify the effort.
Quindi i problemi sono mancanza di usb, cpu cessa, e display segmentato.
In pratica sarebbe stato un altro programma.
