Regolatore YEP 150A 6S (clone YGE) NUOVO
Vendo per cambio programma (nel frattempo tra l'ordine e l'arrivo ho preso un KDE HV da 120A..) il regolatore YEP 150A (2~6S) SBEC Brushless Speed Controller nuovo appena arrivato e mai montato nella sua scatola originale...
Ottimo per elicotteri e funzione Governor veramente efficiente..
Caratteristiche
Specification:
Max Cont Current: 150A
Max Burst Current: 170A for 10 seconds
Input Voltage: 2-6 cells li-XX or 6-16 Ni-MH/Ni-Cd battery
BEC: 5.5V/6A Switching BEC
PWM: 8~16 KHz
Max RPM: 240,000rpm for 2 Poles Brushless Motor
PCB Size: 70x32x15mm
Weight: 95g (including wires)
Features:
Powerful 5.5V/6A Switching BEC
Optional programming card for convenient setup
Super fine throttle resolution provides first-rate and highly accurate linearity
Super smooth adjustable start-up mode
Constant RPM mode (governor mode)
Adjustable F3A brake.
3 steps adjustable normal EMF brake
High anti-interference capability
Low voltage cut-off protection with automatic adjustment for NiCd/NiMH/Li-Ion/LiPo/LiFePO4
Soft cut-off option at low voltage, slows motor RPM gradual rather than hard cutoff (LVC)
Low voltage cut-off can be disabled
Variable cut-off voltage / cell
Active free-wheeling circuit allows for unlimited "partial load" capability
LED status display
Adjustable motor timing from 0° to 30°
Blocked rotation protection (senses a jammed motor and stops motor rotation)
Motor reversing from ESC (no need to change ESC/motor wires)
Over-temperature protection and overload alarm
Throttle signal lose protection. If the signal is lost for 3 seconds, the power will automatically cut-off.
Safe power-on. (Motor will not start until throttle is returned to lowest position)
Prezzo 45 euro + 5 di spedizione. --------------------------- Nome: Angelo Cognome: Enea Città: Mondovì
__________________ I MIEI VIDEO - Extreme Flight MXS 64" - MB339 FLYFLY - TREX 600E Pro DFC Brain - Bixler II FPV - Parkmaster 3D - Maxiswift FPV - Mx2 48" - Drone DJI F450 - Mini Talon FPV
