concordo alla grande !
albero lungo forever
NB. ATTENZIONE !
leggi attentamente quello che suggeriscono nel manuale stretch riguardo alla tensione della cinghia
Very important when tightening the belt on the front side!!!
When tightening the belt, do not tighten the 4 M2,5x12 hex screws that hold the pinion support in place yet.
Just tighten the motor plate screws while keeping the belt tightened as needed.
After the motor plate is secured in position, take the belt off the main gear (pull it up on one side and disengage it) and turn the motor by hand 2-3 times.
With the belt still off, tighten now the 4 M2,5x12 hex screws that keep the pinion support in position.
After the pinion suport is tightened in position put the belt back on the main gear.
Doing the tightening following this procedure it is much better because the belt is not in tension and there is no chance of tightening the pinion support in a bent position.
