Promemoria Per I Campi Che Ospitano Il Cisalpino!!!
TROFEO CISALPINO COMBAT PROFILE/ EPA2014
VISTO LÂ’ENTUSIASMO DIMOSTRATO DAI PARTECIPANTI PER LA STAGIONE APPENA CONCLUSA SI EÂ’ DECISO ANCHE PER IL 2014 DI ORGANIZZARE IL TORNEO DEDICATO ALLA PROFILE /EPA APERTO A TUTTI GLI INTERESSATI ARTICOLATO SU ALMENO 5 O PIU PROVE OGNUNA DA DISPUTARE SUI CAMPI CHE DARANNO PREVENTIVAMENTE LA LORO DISPONIBILITA CON LA POSSIBILITAÂ’ DI EVENTUALI TRASFERTE DA DETTAGLIARE !! SI RICORDA CHE LE GARE VERRANNO DISPUTATE SEGUENDO I VIGENTI REGOLAMENTI E CHE PER ENTRAMBE LE CATEGORIE SONO AMMESSI anche QUEI MODELLI CHE RIPRODUCONO AEREI SPERIMENTALI E PROTOTIPI DELLO STESSO PERIODO BELLICO
PER IL CALCOLO PUNTEGGI MI PARE CHE SIA STATO GRADITO QUELLO DELLÂ’EDIZIONE 2013 ME SE AVETE RICHIESTE O SUGGERIMENTI POSSIAMO DISCUTERNE
DISCORSO PREMIAZIONIÂ….. SE SIETE DÂ’ACCORDO SI POTREPPE RACCOGLIERE UNA CIFRA DIÂ…Â…..XEURI DA RACCOGLIERE IN OCCASIONE DI OGNI GARA PER GARANTIRE A FINE STAGIONE LÂ’ACQUISTO DELLE MEDAGLI O COPPE O QUANT ALTRO PIU COME MONTE PREMI OGNI PILOTA SI IMPEGNA A PREPARARE UN KIT CHE A FINE STAGIONE VERRAÂ’ ESTRATTO A MO DI LOTTERIA COSI DA POTERCI SCAMBIARE SOLUZIONI COSTRUTTIVE E IDEE VARIE ORARI ,ATTREZZATURE, E TUTTO QUELLO CHE RIGUARDA LA LOGISTICA E/O EVENTUALI CARENZE DI MATERIALE DOVRANNO ESSERE POSTATE SUL BARONE IN MODO TALE CHE CI SI POSSA ORGANIZZARE PER TEMPO IL TUTTO TRAMITE LE CONSUETE LOCANDINE LO STESSO VALE PER IL DISCORSO PRANZO OSSIA INDICARE SULLA LOCANDINA SE IL CAMPO HA DEGLI SPONSOR E QUINDI RIESCE AD OFFRIRE IL PRANZO A BABBO MORTO O SE EÂ’ NECESSARIO IL VERSAMENTO DI UNA QUOTA PER AMMORTIZZARE LA SPESA SOSTENUTA PER LE CIBARIE ! QUINDI IL PILOTA CHE VUOLE PRANZARE ALLA GARA NELLA QUALE EÂ’ PREVISTA DALLÂ’ORGANIZZATORE UNA CERTA QUOTA LO INDICHERAÂ’ SUL BARONE INSIEME AL NOME DI BATTAGLIA FREQUENZA E AL NUMERO DI COMMENSALI!!
CAPRALBA DA LA DISPONIBILITAÂ’ PER 2 GARE
GRASSOBBIOÂ…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â… .
GHISALBA Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â….
FUIPIANO (VALIMAGNA) ACCORDI PRO LOCO/ GAB
SARDEGNA (LOCALITA DA DEFINIRE) ASPETTIAMO DARTEN
PARMAÂ…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â …Â…Â…Â…Â…Â…Â…Â…Â…Â…
NOVARAÂ…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…Â… Â…Â…Â…Â…Â…Â…Â…Â…Â…Â…
CALENDARIO DA DEFINIRE
saluti da slow
