Originalmente inviato da flanagan Thanks buddy but I dont' understand why should the winding be different by the triangular one that I always used. Is it due to the number of magnets or just cause if you change the original one (the ring) it's needed to be winded in that manner? |
Triangle / delta is a hook-up, a configuration, it has nothing to do with winding diagrams. The winding diagram depends on the number of statorteeth and on the number of magnetpoles. After winding your motor according to the winding diagram, you connect the wires in star or delta.
A winding diagram table:
http://www.powercroco.de/
-> Tools & Links
-> Kombinationstabelle
