Anche questo sembra interessante Product Details
With the Medusa Research Power Analyzer Pro there is no more guessing as to the performance of your model. It measures nine different parameters real-time including voltage, current, power, amp-hours, watt-hours, RPM, two different temperatures, and thrust as well as the capability to control your ESC. The PowerProView software through the USB interface allows you to display and view plots as well as real time data through user configurable gauges. Using the Pro to control your ESC you can program a test sequence to automatically measure thrust or monitor any of its measured parameters at different throttle settings. Its broad measurement range and high resolution make it just as useful on your parkflier as on your hotliner.
The Power Analyzer is a precision measurement instrument that allows you to accurately measure and calculate all the performance information you need to get the most from your electric model.
- No need to change connections for charging and discharging because the PA Pro can display reverse current as well as forward - Measure down to a single cell with Auxiliary or USB power - High resolution with 10mA current steps and 5mV voltage steps - Personalized and configurable display screens - Because of its wide range and feature rich architecture the Power Analyzer Pro will help maximize the power system knowledge of the novice as well as the serious enthusiast
![](http://www.medusaproducts.com/images/firmware_update.gif)
The PRO keeps you up-to-date with our latest innovations. As always, Medusa Research will offer new versions of the PowerPROview software for the PC,
FREE, when new features are added. In addition to the free PC software upgrades, the PRO now boasts the ability to upgrade the software inside the Power Analyzer itself. The user can perform the upgrade in their own home by downloading the updates from our website and reprogramming the PRO though its USB connection. We call this feature
ISP for
In
System
Programming.
ISP also allows the Power Analyzer PRO you buy today to be compatible with new PRO accessories and features that we may develop in the future.
Technical Specifications
Input Specifications
Minimum Maximum
Input Voltage5 Volts60
Current-30 Amps100
Display Range
Voltage 60 Volts
Current -30 to 100 Amps
Power 9999 Watts
Amp-Hours ±999.999 AH
Watt-Hours ±9999.9 WH
Temperature Channels 1 & 2 0°C to 130°C or 32°F to 266°F (user selectable)
RPM 60,000 (up to seven blades)
Thrust 5,000g
Auxiliary Analog Input** 0.1V - 2.6V, User configurable display value
Display Resolution
Voltage 0.005 V
Current 0.010 A
Watts 1 W
Amp-Hours 0.001 AH
Watt-Hours 0.1 WH
Temperature Channels 1 & 2 0.1°C or F
RPM 25, 50, or 100 (user selectable)
Thrust 0.5g
Auxiliary Analog Input 160µV
Accuracy
Offset ±1 count
Voltage ±0.1% of reading ±1 count
Current ±0.1% of reading ±1 count
Temperature Channels 1 & 2 ±1°C or ±1.8°F
RPM ±0.1% of reading ±1 count
Thrust ±0.1% of reading ±1 count
Auxiliary Analog Input ±0.1% of reading ±1 count
Auxiliary Power Connector Requirements
Voltage 6-30 Volts
Current 30 mA
System Requirements Hardware
Operating System
Windows 98SE, 2000, or XP
Physical Description Dimensions (HxLxW)
57.2mm x 104.8mm x 23.8mm
(2.25" x 4.125" x .938")
Weight
119.6g (4.2oz)
Manuale
Alex
