BaroneRosso.it - Forum Modellismo - Visualizza messaggio singolo - informazione tecnica: cosa si intende per Ncrit?
Vecchio 31 marzo 14, 20:01   #6 (permalink)  Top
mini star
L'avatar di mini star
Data registr.: 30-11-2010
Residenza: Volpiano
Originalmente inviato da romoloman Visualizza messaggio
Basterebbe guardare il sito che ci hai linkato tu...
Airfoil lift and drag polar diagrams
Ncrit value - This is used to model of the turbulence of the fluid or roughness of the airfoil. The Xfoil documentation has a section explaining the method and also the table (reproduced below) of suggested values:-
Situation Ncrit
sailplane 12 to 14
motorglider 11 to 13
clean wind tunnel 10 to 12
average wind tunnel 9
dirty wind tunnel 4 to 8
E anche dalla documentazione di Xfoils:
Transition in an XFOIL solution is triggered by one of two ways:
free transition: e^n criterion is met
forced transition: a trip or the trailing edge is encountered
The e^n method is always active, and free transition can occur upstream of the trip. The e^n method has the user-specified parameter "Ncrit", which is the log of the amplification factor of the most-amplified frequency which triggers transition.
A suitable value of this parameter depends on the ambient disturbance level in which the airfoil operates, and mimics the effect of such disturbances on transition. Below are typical values of Ncrit for various situations.
situation Ncrit
sailplane 12-14
motorglider 11-13
clean wind tunnel 10-12
average wind tunnel 9 <= standard "e^9 method"
dirty wind tunnel 4-8
Note: The e^n method in XFOIL is actually the simplified envelope version, which is the same as the full e^n method only for flows with constant H(x). If H is not constant, the two methods differ somewhat, but this difference is typically within the uncertainty in choosing Ncrit.
The e^n method is only appropriate for predicting transition in situations where the growth of 2-D Tollmien-Schlichting waves via linear instability is the dominant transition-initiating mechanism.
Fortunately, this happens to be the case in a vast majority of airfoil applications. Other possible mechanisms are:
* Crossflow instabilities. These occur on swept wings with significant favorable chordwise pressure gradients.
* Attachment-line transition. This requires large sweep, large LE radius, and a large Reynolds number. Occurs primarily on big jets.
* Bypass transition. This occurs in cases with sufficient wall roughness and/or large freestream turbulence or vibration levels.
The linear-instability phase predicted by the e^n method is "bypassed", giving relatively early transition. Usually occurs in favorable pressure gradients, while the linear-instability mechanism usually dominates in adverse pressure gradients.
If any of these alternative transition mechanisms are present, the trips must be set to mimick their effect. The bypass transition mechanism can be mimicked to some extent by the e^n method by setting Ncrit to a small value --- Ncrit=1 or less. This will cause transition just after linear instability begins. For very large freestream turbulence or roughness in favorable pressure gradients, bypass transition can occur before the linear instability threshold, and in this case trips will have to be set as well.
Grazie mille per la risposta.... Quindi, se ho capito bene, è un numero che rappresenta i disturbi nelle misurazioni dovuti a caratteristiche del profilo o della galleria del vento?
ciao a tutti da mini star!
w la vita, che è la cosa più bella che c'è!
generazione 97
mini star non è collegato   Rispondi citando
