Discussione: Spektrum DX18
Vecchio 26 febbraio 14, 12:25   #1204 (permalink)  Top
rillo75
L'avatar di rillo75
Data registr.: 05-01-2008
Residenza: Bologna
uscito nuovo aggiornamento sw 1.05:
New Features & Improvements
• Added LCD contrast calibration on the Raw I/O screen. If your screen contrast
after the installation is not correct, hold down CLEAR and BACK as you power up
the radio. Adjust contrast with the roller until the LCD shows a good image.
Click the roller to save the setting. The normal System Setting contrast
adjustment may still be used if you prefer.
• The user is able to select an image for the model. From the Aircraft Type screen
select NEXT to access the feature.
• Import File attempts to prevent rebinding when loaded into the same transmitter.
• 250 model memory
• 2/3-Position action is available for the Left/Right trimmers in Acro and Sail
modes.
• GPS supports a “home” altitude. This cannot be used to generate an alarm at
this time, but it does make it easier to understand altitude above ground level. At
the GPS status screen, press CLEAR to set the altitude to 0.
• Telemetry “Settings” menu has new option to auto-populate the list of sensors
reporting from the model at the current time.
• Telemetry logging now supports push-on/push-off toggling on momentary
switches.
• Does not show hidden Mac files and directories in file lists • Added ability to create mixes to channels which were moved using the Channel
Assignment feature.
• Flow across Flight Mode editing screens is now consistent.
• Full support for the Spektrum Vario SPM9589
Corrections
• When using wired trainer, channel 9 is now forced to the Master/Instructor radio.
When using wireless trainer, this is not the case.
• Model warnings now import/export correctly
• Pressing CLEAR on the low voltage alarm setpoint will now select the
appropriate low voltage based on battery type
• Improves connection reliability (same as 1.04D).
• Improved translations in multiple languages.
• Do not give telemetry warnings when in Range Test mode.
• Wiggling switches does not cause a displayed switch to temporarily change
• Trim Include available on Throttle mixes
• Heli Cyclic to Throttle mix now works properly when trims are adjusted. This may
affect the performance of your helicopter if you are using this mix now. Please
verify the new behavior before flight.
• Analog throttle trim is properly displayed on the main screen.
• Slider trim input directions are reversible.
• 4-servo swash now properly protects all swash channels from be re-assigned.
• PowerBox telemetry warnings now show text for the fault.
• Added blinking boxes around Acro/Sail trim settings that were missing them.
• Changing the sailplane icon does not reset servo information any more.
• Corrected the display of the current flight mode in the Flight Mode Names
screen, and changed the flow to remove redundancy with the Flight Mode Setup
screens.
• User-defined warning settings would be changed during import due to an error in
the exported file. Be sure to verify Warning settings when importing a model.
....diffidate sempre dagli aeromodellisti da tastiera
http://www.aeromodellisti-aecibologna.it/
rillo75 non è collegato   Rispondi citando
