Originalmente inviato da Maggi Hello, i m Markus, the man on The pictures and The Wonder of The Second stingray ;-)
I try to answer The questions later...The Problem is, that The google translater is Really working Bad sometimes. |
Hi Markus
I noticed the spar and the housing of the wing joiner are not connected together, not to form one solid block, at least.
I heard that technique, where the joiner box and the spar are separated, is called floating spar (or floating box
![:)](/forum/images/smilies/smile.gif)
My friend Alberto connect "together as one" the spar and the joiner box in our aerobatic machines. We are convinced we obtain higher robustness overall and higher wing rigidity.
ps: congratulations for the wing joiner, a solid block of carbon fiber, looks fantastic.
