Stesso problema, soluzione diversa:
FAA, AMA Work Together on Model Aircraft/UAS Safety
"The FAA-AMA pact is important because the 2012 FAA Reauthorization contained language specific to model aircraft.
Congress mandated that the FAA cannot regulate model aircraft operated according to community-based standards developed by a national organization a designation that AMA satisfies."
Sottolineato e grassetto miei.
Quindi, c'e' stata una richiesta precisa di proibire l'autoregolamentazione.
Tuttavia, sembra che la FAA comunque voglia cooperare con la base per trovare una soluzione.
"Both the FAA and the aircraft modelers group believe jointly working to ensure continued safe operation of model aircraft will comply with the congressional directive."
