Discussione: Nuova Spektrum DX9
Vecchio 24 gennaio 14, 00:15   #281 (permalink)  Top
double68
L'avatar di double68
Data registr.: 27-05-2009
Residenza: Piacenza
Nuova Spektrum DX9
Rilasciato Airware 1.03 con le correzioni di alcuni bachi, la possibilità di cambiare avatar al modello, la gestione vocale anche per il gps ecc..
Release notes (1.03) Changes from Version 1.02
New Features & Improvements
* The user is able to select an image for the model. From the Aircraft Type screen
select NEXT to access the feature.
* Changed default Timer settings from Voice to Tone. This will only take effect as
you create new models.
* Flow across Flight Mode editing screens is now consistent between Acro and
Sailplane and more intuitive.
Corrections
* Removed limitation on Idle Up 3 (Heli) and Flight Mode 5 (Acro) in models.
* Improved voice warning reports of telemetry items.
Audio Changes
* PowerBox status reports are now speak the correct values for capacity. They
were previous 1/100th of the correct value.
* GPS reports both Distance and Heading as separate options available on the
switches.
* Voice may report status of GPS altitude and speed when barometric sensors are
not installed. Note that they are status-only, not alarms, so you will need to use a
switch to activate the spoken status report.
Inviato con il mio Sinclair ZX81
double68 non è collegato   Rispondi citando
