..."Gewickelt wurde pro Strang mit 6x0,3er Draht. (Fiebel 5x0,3...)
9 Windungen pro Spule. Schema ABC ABC ABC.
Das herunterschieben der Spulenköpfe mache ich mit Querdrähten, die nach dem verkleben natürlich wieder raus kommen!" |
Nine winds per coil, 6 wires wound in parallel(flexibility), 0.3mm
... What ABC ABC ABC shema means ? |
'A' means phase A CW, 'a' means CCW. Idem for phase B and C. So in this case, all phases on all teeth are wound in the same direction.
I guess it will be very helpfull to produce a short video with a pratical building session and solve directly most questions. I also guess that the hard part is only starting with the first motor, after that it should be fairly simple.:-) |
Aha, we have a volunteer ;)
Make sure you make the coils as compact as possible, squeeze out all the air. Don't let the opposite long 'sides' of a single coil touch another. Thicker wire, or more in parallel, for higher currents.
For some *&^%$ reason, I could not reach the baronerosso site for a week, other sites were no problem (???). Hence my rather late reply
