Vecchio 02 gennaio 14, 02:37   #155 (permalink)  Top
greywall
L'avatar di greywall
Data registr.: 20-01-2013
Residenza: Foggia
Nuova release Deviation 4.0
E' stata appena rilasciata la nuova versione 4.0 del software Deviation.
Release Notes
Version 4.0.0
Created on Thursday, 19 December 2013 01:00 Last Updated on Wednesday, 01 January 2014 01:32 Written by PhracturedBlue Hits: 327
This is a major release of the Deviation firmware
IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!
Major Features:
Full support for the Devo12 screen
New fully configurable main-page layout
Limited functionality on Devo7e
Minor features:
Protocol-specific telemetry pages
New protocols
V202 (needs NRF24L01 module)
Tactic SLT (needs NRF24L01 module)
Hisky (needs NRF24L01 module)
USBHID (use transmitter as a PC joystick)
Support for 'master' trainer/buddy-box mode
Support for PPM inputs (FPV headset)
Support for RTC in Devo12
Incompatibility:
Switches are now numbered (e.g.GEAR0, GEAR1). Deviation will properly convert old models, but older versions of Deviation will not properly support models made for version 3.0 or newer
The channel scale is applied after the safety value. If safety is in use, make sure to check the values
The toggle icon locations have changed. Generally all models will need to be reconfigured to use the new icons. This was unintentional, but not easily rectified at this point.
If upgrading from a previous Deviation release and using an A7105 module (Flysky/Hubsan), the module will be initially disabled until you follow the directions here: DEVIATION Forum :: Topic: Flysky module users - You need to read this (1/1)
Qui sotto la pagina per il download
Deviation 4.0.0
Syma S107G, Merlin Tracer80, E-Flite Blade MCX2, E-Flite Blade mSR, E-Flite Blade Nano CP X, E-Flite Blade MCP X BL
greywall non รจ collegato   Rispondi citando
