Vecchio 01 gennaio 14, 21:34   #1024 (permalink)  Top
sqltommy
L'avatar di sqltommy
Data registr.: 17-02-2012
Residenza: Taranto
riporto tutto il paragrafo
Trouble shooting:
1 Beeps/flashes: Incorrect throttle curve for Gov.-Store
Mode
2 Beeps/flashes: Under-voltage identification
3 Beeps/flashes: Temperature rise warning
5 Beeps/flashes: Receiver signals failed
6 Beeps/flashes: start up failed
Any error that happens during flight is signaled by the ESC
after motor stop (flashing LED and beeps).
In case the ESC reduces power completely because of
low-voltage, critical temperature, receiver signals lost or the
startup failed, the error levels 2,3,5 and 6 will be stored
permanently (crash analysis). To reset these errors
connect the ESC to the battery with the stick at full power
and/or with 100% throttle pre-selection (throttle curve), and
disconnect it after the interval beep. Please leave the stick
at full power, while disconnecting, otherwise you activate
the RC-Setup.
Alternativly the errors can be cleared by connecting the
ProgCard.
With an activated brake, the error is only signaled after a
tension reset or in wind milling position.
Mqx Mcpx 450X (ex 3d) Atom 500EDGE 540QQ SPEKTRUM DX7s
RC DREAMS ITALIA
sqltommy non รจ collegato   Rispondi citando
