Originalmente inviato da double68 Pare che Spektrum abbia rilasciato l'aggiornamento AirWare 1.02 per la DX9 con la correzione di alcuni Bug e nuove opzioni audio.
Non ho ancora avuto tempo per verificare.
Inviato con Tapatalk |
Confermo
Version 1.02
Changes from Version 1.01
New Features & Improvements
Added spoken telemetry warning reports for more devices.
The BACK button is now enabled while downloading a sound file, allowing the process to be aborted. Note that you will lose spoken sounds if you do this, but most clicks and beeps will still function.
Does not show hidden Mac files and directories in file lists.
Added ability to create mixes to channels which were moved using the Channel Assignment feature.
Corrections
Imported DX18 files will now operate all mixes properly.
Model warnings now import/export correctly.
Pressing CLEAR on the transmitter low voltage alarm setpoint will now select the appropriate low voltage based on battery type.
Prevents lock-ups when using Export All when Unusable Models were listed.
Improved translations in several languages.
Fixed import of Flight Mode sound options.
Lock-ups during import, export and turning on to blank screen have been fixed.
Import errors which corrupted the Flight Mode table have been fixed. These could also cause lock-ups in certain situations.
Corrected position of receiver voltage display on status screen.
Removed limitation that could occur when manually creating models right at the 100-model point.
Corrected export error that made the DX9 unable to import files it created (released in 1.01A).
Audio Changes
Added many new voice items, in particular related to multi-copters and photo/video.
Trainer status changes are now reported when not in Master Override mode.
Spoken and Tone inactivity alarm reports now function properly with vibrator
Intermittent Bind Failed speech after proper binds is now corrected.
Airspeed and current are now reported using the correct units and value.
Reduced default volume for each category to 50% based on customer feedback.
Maximum volume can be increased by using System Settings second screen.
Improved speech and sounds for several languages. Please download the updated sound files from this link:
Spektrum DX9 Support.
Corrected speaking of numbers for French.
PowerBox status reports are now speak the correct values.
Expired timer volume now works off configured value.
