Hi Ron, Tnx for the info. Maybe the traslator leads me in confusion for the six coils, the original sentence in the thread was
"Gewickelt wurde pro Strang mit 6x0,3er Draht. (Fiebel 5x0,3...)
9 Windungen pro Spule. Schema ABC ABC ABC.
Das herunterschieben der Spulenköpfe mache ich mit Querdrähten, die nach dem verkleben natürlich wieder raus kommen!"
From this translation and pictures i was unable to understand how to wind.
I suppose that wire thickness experiment lead to have motors the can be driven by higher or lower currents.
What ABC ABC ABC shema means ?
I guess it will be very helpfull to produce a short video with a pratical building session and solve directly most questions. I also guess that the hard part is only starting with the first motor, after that it should be fairly simple.
Nice to hear from you ASAYC.
:-) Fabio.
