ZYX S2
Dimensions: 37.2mm*25.2mm*13mm
Weight: 9.8g
Operating voltage: DC 3.5V-9V Operating current drain: 40mA
Operating temperature:-15℃~65℃ Maximal angular rate: 2000 degrees/sec
Tail servo compatibility: 1.52ms analog servo, 1.52ms digital servo, 760us digital servo, 960us digital servo
Swash plate servo compatibility: 1.52ms analog servo, 1.52ms digital servo
Receiver compatibility: Conventional receiver, S-BUS, DSMJ, DSM2, DSMX(will support more by firmware upgrade)
Supporting firmware upgrade,Supporting Multi-Blade Rotor Heade
ZYX S
1) Dimensions: 37.2mm*25.2mm*13mm
2) Weight: 9.8g (not including connecting wire and adaptor)
3) Operating voltage: DC 3.5V-9V
4) Operating current drain: 60mA
5) Operating temperature:-15C~65C
6) Maximal angular velocity: 800 degrees/sec
7) Tail servo compatibility: 1.52ms analog servo, 1.52ms digital servo, 760us digital servo, 960us digital servo
8) Swashplate servo compatibility: 1.52ms analog servo, 1.52ms digital servo
9) Radio compatibility: PPM, PCM, 2.4G
10) Supporting firmware upgrade
11) Supporting Multi-Blade Rotor Head
La differenza più grande sembra la velocità angolare aumentata di molto e il cambio dei giroscopi.
Non so a livello software.
-------------- Fabio
Scorpio H15, Blade 450 3D, MQX, Nano CPX ora brushless , Blade 450 Tfbl, REX 500 |
