Vecchio 30 settembre 13, 16:38   #1 (permalink)  Top
Daytona
L'avatar di Daytona
Data registr.: 24-04-2008
Residenza: Cesena
Arrow O.S. GT15 2T 15cc Gasoline Engine
O.S. GT15 15cc Gasoline Engine
benzina a tutto gasssss
O.S. has been adding new engines to the gasoline engine line with the concept to offer the advantages of gasoline engine to more and more modelers. The new addition is the GT15, the smallest size to the line. The displacement is 15cc and well fit in the widely available models designed for 2 stroke 61 size/4 stroke 91 size engines. Very compact O.S. original pump and carburetor are employed for easier installation and handling.
FEATURES
Newly designed compact carburetor (with regulator) expressly for gasoline engine, the 61H and the PD-08 pump are equipped.
Compact IG-06 ignition module is employed.
Special shell type roller bearing is installed at the connecting rod big end. This enables to run the engine with 50:1 mixture gasoline.
Since the mounting bolt pattern is the same as the 65AX, i.e. 52x25. It can be easily installed in the most of existing 2 stroke 61/4 stroke 91 size models. (Minor modification of the mount is required.)
Specifications
Displacement:14.95cc/Bore:27.7mm/Stroke: 24.8mm/Practical RPM 2,000~12,000/Power Output 2.4ps/ 15,000rpm
Weight :Engine 631g/ Silencer 178g/Ignition Module 95g
SPEKTRUM DX10T | Raptor 60 | SAITO FA-56 , O.S. 56FS-Alpha , O.s. FS-30s , West Eurotec .52 v1 | Great Planes SuperSportster 40 | TRAXXAS REVO 3.3|GP Combat CORSAIR| O.S. GF40
Daytona non รจ collegato   Rispondi citando
