Vecchio 18 settembre 13, 00:02   #26 (permalink)  Top
enzino81
Data registr.: 08-09-2013
Residenza: rescaldina
tagliamo la testa al toro, ecco la descrizione del servocomando...
XQ-S5040D 162g 0.18sec/60° 40KG/7.2V Heavy Duty High torque Digital Metal Servo
Description
High torque; digital servo with aluminium middle case 39.8kg/7.2V
6V
7.2V
Specifications: Large Digital servo,metal gears,double ball bearing..
Application: electrocar,gas car,large gas car
Features:Waterproof; Plastic case, resist heat and corrosion; Aluminium middle hull, easy to eliminate heat;Adopt high quality coreless motor.
enzino81 non è collegato   Rispondi citando
