High efficiency 4 poles brushless motor, large size cooling jacket
Redflagpower Exclusive, V2, improved can design for better ventilation
fit 30"-36" size RC boat
Key Features & Specs:
Construction: Sensorless, 4 poles, Y wound
2200kv Leopard 4082 brushless marine motor for RC boat V2 40mm water cool jacket
Hand wound, Precision Large Ball Bearings
2200KV, Max 50000 RPM, recommend work at 25000-35000 RPM
Max power output: 3500 watt, recommend work with 120A or 150A ESC
Work with 4S to 6S Li-Po battery
Motor diameter: 39.8 mm
Length: 82 mm
Weight: 465g (with water cooling jacket)
Axial and shaft diameter: 5mm
Shaft Length: 20 mm
motor mount position: 25 mm same as 540, 550 motor
potrei prendere anche questo dimmi tu quale è meglio e lo manda più veloce
