Secondo me il 550, di seguito le 'novità':
- 550mm main blades
- 6 S Lipo mit 4500-5000 mAh, a luminum rotor head yoke with 8mm spindle shaft
- light und durable chassis fiberglass reinforced frame - direct servo link to the swashplate
- Hollow main shaft with 10mm diameter
- Herringbone main gear with 153 teeth (module 0.7)
- Motor counterbearing with additional main shaft support
- colored fin set in neon red, matched with the canopy
- Extra-strong 22mm diameter tail boom
- Detailed airbrush canopy in neon red
Nota: sul 500 sia il rotore di coda che i palini sono in plastica.
__________________ Mikado LOGO 500 V-Bar 5.3 Pro mini |
