Discussione: Spektrum DX18
Vecchio 19 giugno 13, 17:09   #1072 (permalink)  Top
chrigui
L'avatar di chrigui
Data registr.: 21-07-2006
Residenza: Ferrara - Molinella
1) setup your model as you wish.
2) Once that's done, save the model file to the SD card.
3) put the SD card in your PC/MAC and open it in any txt editor. (I used notepad) You will see all of the info is organized, but a little cryptic.
4) Scroll down until you see "Trim" (not Trim ID)
5) The throttle channel is "Index= 0"
6) Change the "Max Trim Clicks" to 1
7) Change the "Trim Step Size" to 255
8) save the file
9) put it back in your radio, and save it into the proper model
chrigui non รจ collegato   Rispondi citando
