Ho anche trovato questo: "So if your having trouble setting your servo horns to 90 degrees as I was, simply centre all your trims and access your sub trim settings by Holding the right (cyclic) stick in and clicking the left (Throttle/rudder) stick in 3 times. You should here a long beep.
You can now use the trim tabs to move the servos in tiny increments without the trim markers moving for fine tuning your angles"
__________________ Hisky HCP100, Solo Pro 228P, T-Rex 450 Pro V2 (quasi clone), Turnigy9X (mode 1) + OpenTX |
